Tommy
First off I'd like to say hi. Been into nitro rc for years but never really been on these forums.
I'm having some strange running issues with my savage (lrp30) but same issues on the last engine (force28)
Been running the lrp in for the past week or so and all has been going well I have 6/8 tanks left from the fresh gallon I bought to run it in and decided to lean it out to around an 80% tune to finish off the gallon. As I start leaning it out all the normal things happen. Reduced smoke, improved performance, higher rpm and so one. However... although running good on WOT lots of smoke lots of power, when I come off the throttle the rpm's don't drop properly. As if it's running very lean (and it's not) I spent a good hour yesterday and another hour today trying just about every tuning method I know and some new ones that I looked up. But no joy. It's running lean, or atleast seems to be when coming off the throttle. No issues when It's running super rich just as I start to lean it out a little. The leaner I tune it the worse it happens even though, and I stress this. It's not running lean on WOT ifs still a little rich about 80% tunes I'd say. Maybe another 180 degrees turn lean to have a close to perfect tuned hsn.
Things I've changed because of this issue. (Things it can't be)
Tank and fuel lines. Stuck new ones on yesterday thinking that would fix the issue.
Pipe. Same results with 3 differnt pipes. Stock, home made and hpi tuned.
Air leak. Searched for one last night. No luck, sealed it all anyway for good measure.
Drive trane issues. Dragging and what not. Can select neutral and free Rev the engine. Rpm's stay high once coming off the throttle. Less so but it still happens.
Servos holding the carb open. Checked this first and several time since the movement is smooth with no sticking opens full and closes all the way with and without the breaks applied.
My imagination.... Touch and go but it's defiantly running like its lean coming off WOT... I think...
Seriously any help with this issue would be appreciated. With the new engine and bits I've thrown some money at this thing the past few weeks and it's killing me that it's not running right or that I could potentially be damaging my new engine.
I'm happy to take pictures/ make videos and give any relevant information to help.
Thanks a lot, Tommy.
P.s sorry it's a long post.
