Running different size Tires on 4WD
baris41
Hey guys,
Today i made an experiment with different size tires on my savage xs. As you can see in the photo, fronts are standard (outer diameter: 10cm, 4''), rears Proline Badlands around (12cm, 4.7''). Handling improved in return of running all Badlands around. Bashing and flips are way more easy and entertaining. So, would this cause problems on diffs, drivetrain or clutch?
YOU ARE'NT SUPPOSED TO DO THAT ON A FULL SIZE 4WD VEHICLE .
I WOULDN'T RECOMMEND IT ON YOUR SAVAGE. MAIN REASON IS FRONT TIRES ROTATING AT DIFFERENT SPEED THAN REAR .
