Roll Cage
ROCKO9865
hello i was looking for a roll cage for my savage xl. when i run with the body on and holes cut out i still run hotter than when the body is off. no matter how i tune it runs hot with the body so was looking for some feed back on which roll cage would be best i like this one but pricey. http://www.rcnitrotalk.com/forum/showthread.php?t=64843 its like 150.00 or would this be better. http://www.rcplanet.com/SearchResults.asp?Search=savage+xl+roll+cage&Search.x=0&Search.y=0 or does anyone have any other ideas?
I'm running stock picco temps climb up to 280 to over 300 if I'm not care full and keep an eye on it. richen it to the point were any more would give poor performance. run a mc59 glow plug. but with the body off i can get through a tank and temps would be around 275 to 285 and run great. seems to need that extra air flow for some reason and i lowered the truck body down to were the cooling head stands out more above the truck body. also was thinking of getting the nova cooling head and trying that. worked great on my lrp.
I'm running stock picco temps climb up to 280 to over 300 if I'm not care full and keep an eye on it. richen it to the point were any more would give poor performance. run a mc59 glow plug......
Ok, now it makes sense, I'm bettin that Mc59 is the culprit. Before you buy anything, replace that 59 with a MC8 & I'm bettin youll be set :jamout:
Also, if your wanting a cage, then give US Custom Cages a serious consideration.
yes the MC59 is a HOT plug it's for break in..
MC8 is a MEDIUM plug..
Here is a usefull website ::
http://www.scootworks.com/rdrc/gloplugs.html
I will try the mc8 and see how it does. never thought of the glow plug explains a lot! book marked that site to! thanks for the help!
I'm unable to find this drummerguy.... the links are expired and the pages cannot be found....any idea where this guy is??
Sadly drummerguy has not been active for several years now.......
