Robinson Racing spur gear
Rmadrid7
Houston Tx
hello amigos,
I order a Robinson spur gear. My cuestionn is:
Do I need the slip pad on the spur gear? Because it doesn't come whit it... I believe.
Thanks a lot
Not a bad idea to toss on a new lock nut while you are in there too. Then make sure you lock that nut down when you install.
Yes you will need a new slipper pad, go for the ceramic one I hear it is much better
been using this with no problems whatsoever Robinson racing gen 3 direct fit no mods you can also run it with the nut backed out for some driveline protection nice piece
