Removing reverse from transmission
Subord
I have a Savage X 4.6 with reverse. Reverse has been nothing but trouble so removed the servo and electric box. The linkage or fork that slides the gear naturally wants to slide to neutral. I took the transmission apart.
My question is does anyone know the best way to lock the little gear into the main gear or is there a replacement shaft or gear to accomplish this?
My idea was make a notch (3rd picture where the pen top is pointing.) in the shaft and use a C clip to hold the sliding gear inside the main gear.
I thought I might check on here first in case there is a better way.
Any help or suggestions appreciated.
Thanks
Oops. I put 2 pictures the same.
