rehargeable 5 cell humpback
bobbd
does anyone have the schematics on the humpback mod to show where all wire connections go. thanks
see page 21 of the manual. also you may have to get a new switch depending if your battler you are going to be using has a mini jst or a flat receiver type plug.......
http://www.ebay.com/itm/like/302028275445?lpid=82&chn=ps&ul_noapp=true
^^^^^^^^^^^^^^^^^^^^^ that one has a flat receiver plug which may require a new switch harness
http://www.ebay.com/itm/like/332073258702?lpid=82&chn=ps&ul_noapp=true
^^^^^^^^^^^^^^^^^^ that one has a mini jst type plug and you will need a corresponding wall charger to juice it up
To supplement what Jam has said, here is the page from the manual. The lower left hand corner shows adding the optional charge jack, so you no longer have to remove the hump pack to charge it.
