i just read about a rear wheel steering kit, but i cant for the life of me remember where. if i can find it again il post up a link.
rb innovations has a rear wheel steering module:
www.rbinnovations.com/catalog/produ...d/148?osCsid=10f633b1ba86bfb2e6a74ba8d2cdf341
Thanks buddy another ? what about the radio to you have to get one that you can adjust the turnning of the rear wheels how does that work??
The radio I use personally is the Spektrum, it allows independent operation of the rear wheels. In other words I can use that radio and just drive by steering only the rear wheels if I want to.
Some radios allow you to mix the 3rd channel to the steering channel and you can have the rear wheels turn at a % of the front wheels.
For other radios, I do have a Y harness that you can plug into the receive steering port and it has a adjustment to center the rear wheels, while you can use the radio trim to adjust the front wheels. The only down side of this is the rear only turns the opposite of the front (no crap walks)and turn at the same rate.
do you lose any power to the servos using the y-harness? since you're running 2 servos with a channel meant for one i mean...
also, does anyone know where i can find a book called "Programming your Spektrum for Dummies"? so i can set mine up to run like that?
