Problem engine
ReVoX
Italia
Hi everyone, I purchased used Octane savage but can't get it to work well. As soon as it work up it engine switches off...if I lift the wheels and accelerate I can listen the engine not working properlyv(with avoids).
1 The spark plug is full wet with oil / petrol, it is already the second ngk cm6 spark plug that I change, I have set the carburettor high screw 1 turn and L screw 1 turn and 7/12 as recommended by HPI but it looks very fat.
2 I use motul 800 2t off road at 4% (1 liter = 40ml oil), being very dense....can I go down to 2 or 3%? From the online videos you can see the light tank, mine is deep red due to the oil.
3 The spark is correct and noise is heard when I test with the spark removed (especially in the night with light off), could it be a defective / damaged CDI HPI? In this case, how can I understand that it is the control unit and not the carburetion / spark plug?
4 if i wanted to change cdi with rcexl instead of the original HPI is it ok anyway?
