PlatinumRCProducts Kits/Parts & Prices!
Larsenracing
Manufacturer
Worthington, MN
This list will be kept up to date so check back to seen new products. For pictures please see website www.platinumrcproducts.com
Part Num----Description (Made out of)----Price(USD)
PRC101----Losi Slider Modified Chassis(2MM CF)----$40.00
PRC102----Losi Slider Chassis (2MM CF)----$24.00
PRC105----Losi Mini LST Lower Skid Plate Kit 3Pcs.(2MM CF)----$30.00
PRC107----HPI Savage Ext. LCG TVP Kit (4MM CF)----$134.40
PRC110----HPI Savage Engine Plate Kit (4MM CF)----$30.00
PRC112----HPI Savage Servo/Mid-Tank Plate (4MM CF)----$30.60 (Accepts Hellfire tank HPI#87505 (not included)) CLICKY-Check my build out
PRC113----Thunder Tiger Mini Titan Tail wind (2MM CF)----$18.00
PRC117----HPI Savage Ext. Skid Plate Kit (4MM CF)----$33.60
PRC118----HPI Savage Ext. LCG Chassis Kit (Includes PRC107 & PRC117)----$159.60 (Best Value for Ext. chassis)
PRC122----HPI Savage Roll Bar (4MM CF)----$42.60
PRC125----HPI Savage OFNA Mid-Tank Plate (4MM CF)----$34.80 (Accepts OFNA 250cc tank OFNA#OFN19504 (not included))
PRC128----HPI Savage LCG TVP Kit (4MM CF)----$120.00
PRC130----HPI Savage Skid Plate Kit (4MM CF)----$33.00
PRC131----HPI Savage LCG Chassis kit (Includes PRC128 & PRC130)----$145.25 (Best Value for LCG chassis)
PRC133----HPI Savage Shock Tower Kit (Compleat Truck)(6MM CF)----$75.00 (Require use of Hellfire body mounts # HPI85514 (2-needed))
PRC138----HPI Savage LCG Shock Tower Kit (Compleat Truck)(6MM CF)----$65.00 (Hellfire shocks or simular) (Require use of Hellfire body mounts # HPI85514 (2-needed))
PRC139----HPI Savage Shock Tower Kit (1 Set)(6MM CF)----$37.50 (Require use of Hellfire body mounts # HPI85514)
PRC140----HPI Savage LCG Shock Tower Kit (1 Set)(6MM CF)----$32.50 (Require use of Hellfire body mounts # HPI85514)
PRC145----HPI Savage Wing Mount Plate (4MM CF)----$11.50 (For use with Hot Bodys wing mount #C8152)(Designed to fit with our Shock Tower's but can fit stock towers with minor modifications)
PRC149----Thunder Tiger Raptor 30/50 Tail Fin Kit (2MM CF)----$40.70 (Includes both vertical and horizontal fins)
PRC150----Traxxas T-Maxx Nitro Chassis Plate (4MM CF)----$71.00
PRC151----Losi Mini-T/Slider Front Brace (2MM CF)----$12.50
PRC153----HPI Savage Bulkhead Lower Plate (2MM CF)----$20.00
PRC154----HPI Savage Bulkhead Lower Plate Kit (2MM CF)----$37.00 (Includes 2-PRC153)
PRC157----HPI Savage Brake Kit (1-4MM, 1-2MM CF Disc)----$14.50 (Replaces Stock Red Fiber Discs)
PRC158----HPI Baja 5B Rear Lower Plate (4MM CF)----$65.00
PRC159----HPI Baja 5B Rear Upper Plate (4MM CF)----$30.00
PRC160----HPI Baja 5B Rear Lower Brace (4MM CF)----$10.00
PRC161----HPI Baja 5B Rear Lower Front Brace (4MM CF)----$8.75
PRC162----HPI Baja 5B Front Upper Plate (4MM CF)----$35.00
PRC163----HPI Baja 5B Gear Plate (4MM CF)----$28.75
PRC164----HPI Baja 5B Front Lower Brace (4MM CF)----$8.75
PRC165----HPI Baja 5B Front Upper Brace (4MM CF)----$10.50
PRC167----HPI Baja 5B Brake Holder Plate (4MM CF)----$8.30
PRC168----HPI Baja 5B Engine Mount Kit (2-4MM CF Plates)----$19.00 (Includes Right and Left Plate)
PRC169----HPI Baja 5B Brake Disc (4MM CF)----$15.00
PRC175----HPI E-Firestorm Battery Tie Down (2MM CF)----$15.50
PRC176----HPI E-Firestorm Servo Brace (4MM CF)----$8.50
PRC177----HPI E-Firestorm Front Brace (4MM CF)----$10.00
PRC178----HPI E-Firestorm Carbon Fiber Kit----$31.50 (Includes 1-PRC175, 1-PRC176, 1-PRC177)
PRC180----HPI Savage X Rush Battery Box Plate----$8.00 (Fits X. XL Shock towers)
PRC181----HPI Savage 21/25/PRC Rush Battery Box Plate----$8.00 (Fits 21/25/PRC Shock Towers)
PRC182----HPI E-Savage Wing Mount Plate (4MM CF)----$12.00 (For use with Hot Bodys wing mount #C8152)
PRC183----OFNA/Jammin/HOG-NOR CR/CRT Diff Mount Plate Center (2MM CF)----$14.75
PRC184----HPI Savage X Wing Mount Kit (4MM CF)----$19.75 (For use with Hot Bodys wing mount #C8152)
PRC188----HPI Savage FLUX Chassis (4mm CF)----$120.00
PRC189----HPI Savage FLUX Motor Plate Kit (4mm CF)----$27.50
PRC192----HPI Savage FLUX Extended Chaissis (1.5" Rear)(4mm CF)----$136.80
PRC194----HPI Savage 21, 25, SS, X, XL, FLUX Radio/Tank Tray Kit (4MM CF)----$30.00
PRC195----HPI HellFire Shock Tower (Single) (4mm CF)----$23.75
PRC196----HPI HellRife Shock Towers (Set) (4mm CF)----$46.25
PRC197----OFNA CRT Upper Front Brace (4mm CF)----$16.50
PRC198----Team Losi 8ight-T 2.0 Front Shock Tower (4mm CF)----$25.50
PRC199----Team Losi 8ight-T 2.0 Rear Shock Tower (4mm CF)----$31.25
PRC200----Team Losi 8ight 2.0 Front Shock Tower (4mm CF)----$20.50
PRC201----Team Losi 8ight 2.0 Rear Shock Tower (4mm CF)----$28.00
NEW
PRC202----HPI Savage FLUX Extended Motor Plate (4mm CF)----$38.00
PRC205----HPI Savage FLUX XL Extended Chassis (4mm CF)----$150.00 (HPI86054 Drive shaft not included)
PRC207----HPI Savage FLUX XL Extended Skid Plate (4mm CF)----$48.00
PRC208----HPI E-Savage Lower Bulkhead Plate (2mm CF)----$20.00
PRC209----HPI E-Savage Lower Bulkhead Plate kit (2mm CF)----$37.00
If you have questions feel free to ask. Again this post will be updated as new kits/parts come out.
For cad picts see https://www.hpisavageforum.com/forums/showthread.php?t=5301
Larsenracing
Manufacturer
Worthington, MN
Shipping and handling is calculated via the USPS web site. Typically in the USA we ship everything via USPS Priority mail and anything international goes USPS First-Class.
Generally we can ship anywhere in the US for $7.00 via Priority mail and generally arrives with in 4 business days but on a seldom occasion they are slower than that. If you have a large order the amount varies some due to weight. If orders are over $150.00 we generally require insurance.
On international shipments we do quote from the USPS site and give the best price possible. Typically is around $12.00 but it all depends on where you live.
We are not at all like ebay sellers and mark up shipping & handling to get rich off of it.
Shaun
Canada
man your parts list is really growing!! and i checked out your website some real nice looking items, great job!!!!
Larsenracing
Manufacturer
Worthington, MN
Thanks man and yes it has growen quite rapidly and soon to grow much more. My web site should be updated soon with all of these parts.
Larsenracing
Manufacturer
Worthington, MN
Well we have added a few more parts to our product line. Some of these parts include Shock towers for the Team Losi 8ight Buggy and 8ight-T truggy 2.0's and a front upper brace for the OFNA CRT.
We will continue to add parts. Keep in mind if you need anything or have anything that you would like please let us know and we will look into it.
Larsenracing
Manufacturer
Worthington, MN
Added some new parts, Most include the FLUX XL Extended Chassis kit and Skid plate. We also added a line of Lower Bulkhead plates for the E-Savage because the Nitro Savage Lower Bulkhead plates are selling so well.
frddyj
boston
Jason anyway you can get someone who has these mounted up to snap a pic?
ive been wanting em but noticed that the stock ones have a bend in em so i wanted to see how they mount up before i pull the trigger.
hpisfgreen
carldav
AUS
Good day Larsen, I noticed the PRC link no longer works...any chance if you are still selling Savage hop-ups? I am interested at the wing mounts? Thank you.
Jam Racing 1
HPISF Supporter
Sorry but I do not think Larsen is making things any longer :( last post on this thread was 5 years and 7 months ago.....
Jam Racing 1
HPISF Supporter
Ya for sure, a search for his site seems closed and is nothing savage related on E Bay either.....
