turn the crankshaft and get some needle nose pliers and carefully pull it off the pin. Might have to wiggle it some lol
NO no, use a tiewrap. Zip a tiewrap on the conrod and pull gently on the tiewrap until the con rod slips off the crank pin.
Needle nose pliars! geez:stickspank:
thanks for all the help ive managed to get it off and out now
thanks again 4x4
I didn't say strach the hell out of it, did I, its a connecting rod,
Thats a good Idea, tho... I just use pliers, and pull it off no big deal
:duh:
How did you get it off (just curious)
I wasn't try'n to say your way is wrong, I used to do it that way myself. Then once I noticed that even after I was very carefull the little groves at the tip of the needle nose pliar had small metal shavings in them. I looked closely at the edges of my conrod and saw little cuts, no biggy right. Two days later I fry the rear bearing and guess what I find in it, yup little aluminium shavings from the tip of the pliars.
No matter how carefull you are you will in most cases try a little too hard to remove the conrod and make shavings with pliars. I found the tiewrap to be a safer and more secure way of removing the conrod. You can also use a couple of tiewraps stood on end to press out the sleave with the piston. It only lifts the sleave up a little bit but in most cases it is all the room you need to get a hold on it and pull it out.
