- Worthington, MN
Well, I decided to take one of my Axial 28 Spec 1S engines last night which has been run in my basher and do some porting and polishing on it. This is my first time for doing this so I hope i’m doing it right. Anyhow, I got a start on porting things but haven’t even started polishing anything yet so its rough. I am using my dermal with a stone grinding but next time will get a carbide bit. Here are a few picts of the sleeve which is the only thing I’ve done so far.
Stock Exhaust port
Can you guys see am I doing anything wrong?
Also, what do I all need to do to the Crank other than polish it?
Is there some cutting I should do to the skirt of the piston?
If any of you have picts of a Axial 28 Spec 1S modded can you please post then here as I would like to see others jobs. I will post more picts as I go.
Stock Exhaust port
