MikeK1981
ChondroManiac
- Humboldt, CA
OK I replaced my OWB and starting shaft and they seem to be working OK but now it slips when the motor is cold. It's kinda wierd it grabs enough to turn the motor over once, sometimes twice but rarely, each time I hit the button on the roto-start and then it just spins. I can still start it by just tapping the button a bunch of times kinda like when you use a pull start and once the motor is warmed up it does not do this anymore and it works as it should. If I take the glow plug completely out it works fine too even when cold but as soon as there is compression it slips again. I think it is just the nitro fuel making it slip and I checked both parts for damage and they still look brand new (no wear on the shaft) but I'm afraid over time this extra sliping will wear down another shaft. I'm already on my third one LOL but I think the first two wore out because of that OWB being bad. Is there a good way to clean these parts and keep them working good for longer? I wiped them all down and it work good for the first couple pulls with the starter but then started slipping again. I noticed there was grease in the OWB when I got it and now it seems as if the nitro fuel kind of washed it away does it need to be re-greased after I wipe it down?
