OS GT15HZ Piston Ring, Piston Liner and Pin Retainer fits on my GT15C!
Discussion in 'HPI Savage Octane' started by L0r3x, Aug 18, 2016.
  1. L0r3x
    L0r3x Active Member
    50
    15
    Oct 5, 2015
    After almost 2 years of weekly bashing with my savage octane, the compression was finally gone. And due to scarcity of parts last month on the net, I was forced to gamble on the parts of the GT15HZ. And boy I was so glad that all of it fits in my engine.
    And here are the old parts. (the ring was already thin that it snapped while I was carefully taking it out)
    And so, fingers crossed, I tested the engine for the first time to see if it will start. And clenched my fist as I hear it revs after a few pulls. I let it run on idle for 15mins to check and hear any unusual sound and there was none.
    I'll be breaking her in over the weekend and see her roaring again.
    Peace!
    • Useful Useful x 2
  2. F-Type
    F-Type Well-Known Member
    246
    16
    Apr 15, 2015
    Gothenburg - Center of the Universe
    Lucky you, in every way ;)
    • Like Like x 1
  3. francis Labarbara
    francis Labarbara Well-Known Member
    456
    66
    Oct 9, 2015
    West Virginia
    I was about to do that and someone posted a link to a new engine that was cheaper then the parts.
  4. L0r3x
    L0r3x Active Member
    50
    15
    Oct 5, 2015
    What engine is it?
  5. francis Labarbara
    456
    66
    Oct 9, 2015
    West Virginia
    GT15c
    • Like Like x 1
  6. Razaablak1
    Razaablak1 New Member
    2
    0
    Jan 22, 2017
    Can u replace the piston ring without replacing the piston and sleeve I.E. usIng the existing piston and sleeve with the new piston ring
  7. francis Labarbara
    456
    66
    Oct 9, 2015
    West Virginia
    You can if the piston isnt damaged. Slightly scuff the sleeve and then break the engine in again.
  8. smoose
    smoose Member
    11
    2
    Feb 20, 2017
    whats the best way to break in this engine. thanx to you I rebuilt mine with a new o.s ring which was the only component that was worn out. also what type of oil are you running
  9. F-Type
    246
    16
    Apr 15, 2015
    Aha, I didn't realize you had been running your Octane that much, smoose, enough to wear the ring out, then it's no wonder you had such a big gap. ;)
  10. Razaablak1
    2
    0
    Jan 22, 2017
    I use standard 2 strike oil just die it around slowly 2 vreeak in... I have converted mine now to brushless engine gave problems again
    • Optimistic Optimistic x 1
Verification:
Draft saved Draft deleted
Share This Page
