The reason they mention it for just the front could be because of the steering.
Has anyone got an idea what type of spray I should use? They say WD-40 is bad for plastics.
Oil for all bearings, I remove them clean with denatured alcohol and let dry well, then put on a clean paper towel and oil the bearing until I see oil on the paper towel and then reinstall where they came out of, as for WD40 being bad for plastics that is a first for me I use it for keeping mud and buildup off my rig, it really helps come cleanup time....
Wd40 can soften plastics a little, makes them less brittle/ more flexible, used to be common to soak (for a few hours/days a-arms in wd40 for durability. I do not think it is "bad" for plastic.The reason they mention it for just the front could be because of the steering.
