I have nearly 1 gallon through my truck so far. The only problem I've had with the truck has been an intake leak after the carburetor bolts became loose. I have been doing hours of reading online and it seems likely that the engine is a descendant of the OS GT15HZ? That engine has a terrible online reputation. The early versions lost the piston ring locator allowing the ring to rotate and snag in a port. The "new" pistons tend to lose the wrist pin circlips. Apparently the failure occurs within only a few gallons of operation. I just read one post on here that a member's engine lost a clip. Has anyone else lost a circlip or had a ring rotate and catch a port? Does anyone have a "high mileage" motor running strong after dozens of gallons?
