ElocFSU
- Houston, TX
Hello all,
So I've completed my break-in process and I've run another 2 or 3 tanks with my new Savage X. Been a blast thus far. I have a few questions about the nitro start unit.
I've noticed that it frequently has a hard time turning over the engine. Often times, it will start rotating but then the nitro start clutch will release and disengage. In this case the engine stops turning over and I have to release the nitro start button and try again. I am assuming (and hoping) that this is because my engine is new and the pinch is hard to overcome.
My question is a simple one. How does the nitro start clutch work? I see settings from 1 to 3 or so on the rotating dial. Manual says to use position 1. Does a higher number result in more torque being applied before the nitro start clutch disengages? Or is it the opposite? What clutch setting do you guys run?
I have read that, given the new engine, I may need to consider starting with the glow plug slightly loosened to reduce compression. Not sure if I should do that or if I should increase the drag setting on the nitro start to apply more torque.
Thanks!
Thanks!
