Lowking716
So I spent some bucks on a losi LST from a guy a city away from me its a great truck paid 200 but I'm having a problem with it starting, the piston is getting stuck at the top of the sleeve and I believe it broke the casing for the owb in the losi spin start plate so its slipping and not turning the crank especially with the sticking problem, if I loosen up the piston via the flywheel it'll only get to the top of the sleeve and doesn't have enough power/grip to turn it out of the pinch. So my questions are
1. Could someone direct me to the replacement part I've looked all over the web and don't believe I'm using the right terms to find it or is there some type of jimmy rigging I could do to get it started because I feel like the way its set up is kind of silly lots of parts but I'm a noob so what do I know.
2. And ive read up a little on the piston sticking some people say its normal but to me(again coming from a nooby) isn't healthy I checked to see if anything was shredded or dirt got in there and it looks pretty clean.
