Miximizer Rims
  • Thread starter Thread starter JohnH
  • Start date Start date
J
JohnH
Guest
Maximizer Rims
Maximizer Products
http://www.maximizerproducts.com
866-293-4244
Warranty
Warranty For Maximizer Products, Inc.
Maximizer Products, Inc. warranties all of our products against defects in materials and workmanship within 1 year of purchase. Some items are subject to wear and are sold individually for your convenience. Please refer to our Replacement Parts page.
The warranty of goods is subject to the following conditions:
1. The products must not have been modified or altered in any way.
2. The products may not have been used for purposes other than those intended by the manufacturer.
In the event that circumstances are found to exist which the Purchaser believes may give rise to a claim under the warranty, the following procedures shall be followed:
1. The Purchaser shall contact Maximizer Products, Inc. either by phone (1-406-755-2828) or by email ([email protected]) and explain the circumstances and facts of the warranty claim.
2. If deemed a legitimate warranty issue, Maximizer Products, Inc. will require the purchaser to return the defective piece at the Purchaser’s own expense to:
615 Scenic Drive
Kalispell, MT 59901
Along with the Purchaser’s name, return address, phone number, place of purchase and purchase date.
3. Once the item has been received, Maximizer Products, Inc. will return an identical or otherwise comparable replacement part to the Purchaser by US mail at no charge.
Except for the warranty set forth above, no representation or warranty made by any sales or other representative of Maximizer Products, Inc. or any other person concerning our products shall be binding upon Maximizer Products, Inc.
Truck used:
HPI SAVAGE X SS http://www.hpiracing.com Kick *** trucks
SURE FIRE .32R http://www.racers-edge.com Wicked engines and goodies
ROCK CONCEPTS TVP's http://www.rockconcepts.net Excellent tvp's and upgrades
OS30VG http://www.osengines.com Nice engines and been around since Moses
BUKU Performance pipe https://www.bukupower.com The only pipe I will run
Zero offset Beadlock wheels with 14mm hex drive for 3.2†monster truck tires also know as Maxx size or MT.
Features: Composite Beadlock wheel system: Inner rings lock in the bead of the tire without glue.
Ring Shims are included for use with thin bead tires such as:
HPI: Dirt Bonz, Dirt Claw
Losi: King Pin
Imex: Swamp Dawg, Claw Dawg, Dirt Dawg, Rib Dawg, Baja, Road Dawg, Pin Dawg & Trail Dawg
ProLine: Maxx Bow Tie, Maxx Road Rage, Maxx Paddle, Maxx Mulcher, Badlands, Crimefighter MT, Holeshot MT
Includes: 2 Beadlock wheels which consist of 2 Tubes, 4 inner rings, 4 ring shims, 2 faceplates, 16 screws and instructions.
Requires: Metric screws require a 2.5mm hex wrench
Specs: Total width: 2.2†(56mm) Inner width: 2†(51mm) Diameter: 3.2†(81mm)
SKU: 1122
PRICE: 29.95
Pkg 8 Black Rock Rings (4 of each design)with 32 screws.
Note: Only works with Maximizer Beadlocks, not recomended for X-75.
SKU: 2221
PRICE: 16.95
These are the retail prices for the Maximizer rims I'm running. I will not use stock rims anymore to bash. I'm so hard on rims and tires and a complete set of tires and rims every couple of months is beyond me. I have ran these rims and the red ones for almost a year. I have done some very off center jumps with them to try and break them and other parts on the truck for reviews. It seams I'm doing something wrong because I'm breaking everything I don't want to............. The 14mm hexs look new. There is no wear on the edges and this is one thing I have done to stock rims often. Wear the hex out on the hub or shatter it completely. I haven't had this happen at all. I have blown the bead a couple times but that is do to me running tires that were glued onto another set of rims. I boiled them and slapped them on these rims. I love the fact on how they are constructed and they don't use 30 plus screws to hold them on. They are lighter than the Proline rims and on Par with the Axial rims. I like that I can change the hub to another color without buying another set of rims. All I have to do is order a new hub and I'm good to go. Ryan and Adam Anderson have a set and love them to. They have only busted a bead once and that was .........God only knows with those two..... It was either on the grave digger jump or the free style when they were doing donuts. The guys that I have talked to that run them love them and will not give them up. The guys that win them at our event's can't wait to run them. The styles to choose from is quite nice. If you want off set or not they have you covered and if you even want aluminum your good to go.
The customer service is excellent with Maximizer. Every time I have called them to talk about products they have had a great ear. So give a set a try. The hardest thing to do will be to pic a color and offset.
As for my ratings:
Tunability N/A
Performance 10
Part quality 10
Value 10 (just add up the cost of all your rims and tires that you have tossed)
Good +
rims are practically indestructible:nutshot:
Quality of work:resp:
options and interchangeability with other Max rims and components:rock:
Made in America:salute:
Bad-
Price If you have a tight budget this will hurt some:stickspank:
got a lot of tires to boil off of old ruined rims:duh:
:10:
More to come
By Megabyteme AKA John
Thanks guys still have a lot of work to do. 4x4 what is with that cat and dog dude. Nice pic. Wish it was a little bigger so I could laugh harder.
Normally I wouldn't have mentioned it and I have noticed this before but I was so bored I thought I'd mention it for something to do.
I just love those Miximizer rims, they nearly perform as good as the maximizers.
Jks, I thought it was just a cheapo knock-off of Maximizers.
Great Review BTW!!!
Good review, Maximizers cost less than the Axial Beadlocks, and have more colors and choices. Definetly good to get to cure the CA blues. Thanks for the review.
