mid tank 25 using stock tank
josh62685
i pretty much have everything done but have it apart right now because it got in a wreck and i have to fix a few pieces. anyways i used a plastic box from radioshack for the rx. i mounted it inbetween the handle bars.(had to reshape the handle a little to make it wider) the battery is staying in the same place, so is the steering servo. i mounted the throttle next to the engine. as for the tank... i gutted the throttle servo location and placed the tank there. i made a top plate out of aluminum to replace the plastic one to hold the battery and tank in place.. i cant explain good, the pics will do the talking. i will get more pics of everything when i have the truck together.
Cool mod and welcome to the forum. Does the height difference help any with half tank lean even though the tank still has the step in it? Or is this mod purely for weight distribution?
its just to keep everything on the inside the truck, my old tank got cracked from something hitting it. i never noticed a problem with half tank lean. never heard of it until i came on this site.
