I have a used 4.6 X that came with an LRP Z.28R that hasn't ran in about 8 yrs or so. Two weeks ago I started a methodical assessment of this rig and found that the engine wouldn't pull over. Since I bought the rig used and only ran it for a short time I was thinking a tear down of the engine and the rig in general was the way to go. I flooded the intake with Kroil and after a few hours was able to turn it over by hand. It seems to have decent pinch so I dove in on the carburetor first. The slide seemed to drag horribly and it wasn't just due to sludge build up. I cleaned it well and still it dragged. I polished the slide piston with 0000 wool and was finally able to get it to move freely.
Questions:
* Was using the wool to get the slide to move a good idea?
* O-rings on the needles look good, should I replace them or just go with it?
* More to the point, Should I go ahead and tear the engine down the rest of the way, clean and lightly polish the piston and crank, replace the one way bearing and seal it back up?
Thanks , this is purposely a work in progress
Questions:
