Little to no braking power
Neil77
No brake or very little when car is running.. please help..
We need more info. What brake setup does it have? Steel disc? Pink composite discs? Are you running the stock throttle setup? Pics will usually help.
Check simple things first. Battery charged fully. Screws on servo tight. Set screw on brake arm tight. Screws holding brake discs to trans tight.
We are gonna need a bit more info, are you running a rechargeable receiver pack ? linkages setup correctly? many things will affect your braking power....
