AoD
- Hammondsville, Ohio
I'm on the hunt here.. I need a second battery that can be charged with my charger. This is a picture of my charger and battery I currently have...
https://www.hpisavageforum.com/forums/attachment.php?attachmentid=1486&d=1207597328
Now, I would like something with a bit higher of a mAh rating. My battery, with my ESC setting on low power/long battery life runs about 25 minutes or so. I know I can't race a 20 lap oval race with that, seeing as how I'd be on the throttle then a lot more. At the LHS, they have 2 heats and a main, and one battery just isn't going to cut it. Specially when I get a 6800 or 8000Kv motor for it. The battery can be a little wider, but must remain the same length and height, as the chassis has an adjustment for battery width. I want a 3 cell LiPo, 25C rating at 11.1v. 1350mAh would probably hold for one race, but then it'd most likely be done, or close to it. I've found hundreds of nice LiPo's for around 40 bucks (which I'm willing to pay). But, none of them fit my size brackets. Here they are for you.
Battery Stats:
Length: 4" (101mm)
Width: 1-5/16" (33mm)
Height: 7/8" (22mm)
3S (11.1v) battery pack
Standard Tamiya power plug and a mini balancing plug
Those stats are directly from my battery. I need something similar, and/or better.
Battery Stats:
Length: 4" (101mm)
Height: 7/8" (22mm)
