K4.6 starter hex size?
Madara
Does anyone know what pull starters will fit the k4.6 from a Savage SS? Not a k5.9. I've tried a few pull starters I had laying around but they were all too big. Any ideas?
I believe the hex is 11mm and Axial pull starts should fit, if you can find them. k5.9 pull start should also fit, so probably easier to find.
The K series engines use an 11mm hex starter shaft and trying to find a pull start or roto start to fit these mills is now on impossible. I have 6 of these K mills and have found that the starter shaft from an SH.2.8 or Dynamite .26/.28 can be used as a replacement. These shafts are 12mm and not 11mm so will allow you to use any 12mm pull/roto start.
I was buying them from RC Scrapyard but didn't know what engine they came from, so I asked the question and Jam1 came up with the answer. Have now found that Wheelspin Models stock them.
https://wheelspinmodels.co.uk/i/75169/
https://rcscrapyard.com/pull-starts...haft-fits-xtm-sh-force-and-converts-hpi-ts004
