jp3 pipe, fit issues?
xyzflix
are you guys using stock header with this pipe because the new one fit SUPER tight...
tips would be nice.
Try a smaller header gasket. The GS ones are nice and thin. Come in cool colors too.
not having a problem there... its the bigger wider bend on the header hitting the rear shock. more like pushed up against it.
You really need the ext chassis or lsts with that header. Try a sts header. Its shorter
He probably has the Integy Rear hub carriers which eliminate the rear tie-rod otherwise the AtomicRC ones which are like the same. O ya he could also have the HPI suspension kit.
Like said from Grumpy try the sts header as it will work great for your application.
I have the Intejunk rear rod eliminators. The only Intejunk product I think is descent. Everything else I had by that brand broke quickly. The tank guard on my max broke the first day.
