Scottbot302
- Somewhere in Illinois
Hey guys, so as some of you may have seen on my other post, I need a collet to complete my savage clutch rebuild. The last one was incredibly worn and had a crack at the base of it. So I decided to throw it out. When I got my flywheel, it came with a collet so I thought it would be great since I could replace it right then and there. I came to find out after reassembling the clutch that the collet might be the wrong size, even though it came with the flywheel I needed. I triple checked the part number and made sure I had ordered the correct part and everything. After putting the clutch assembly back together I measured the distance from the Block to the back of the flywheel. It came out to be 2.25mm. I started looking around and realized the collet I needed i said to be the 7x6.5mm one. Which is the one I think I received? People have said that you need to torque that nut on the flyhweel really hard, after trying multiple times (the engine would only turn over and not tighten because it was so tight) I was still getting the 2.25mm gap. The reason that gap is an issue is because if I get a decent gear mesh, the holes that you screw the bolts into wont line up. I reallly don't know what to do at this point. Help!
