I need help please to find a part
ImYOUNGagain
Texas
I just got a novarossi rex 28-8 i need a way to start it pull or roto but it came bump start ready but i have no way to bump start a savage. Or can i put a gear on a drillbit and use that maybe?
Jam Racing 1
HPISF Supporter
If it is Bump start only then no you can not use any other way to start the :ercm: because it is missing the pin on the crankshaft required for a pull or rotostart to be used....
Jam Racing 1
HPISF Supporter
See the end of that crankshaft?? your new engine will not have that needed area for the pullstart to grab onto for starting......
ELWOOD
HPISF Supporter
So.Cal.
I see that Novarossi offers the Rex 28 8 in Roto and Pull start, I don't see why u cant purchase a RS/PS kit .
olds97_lss
Dekalb, IL 60115
You would need a new crankshaft, backplate, one way bearing, starter shaft, starter.
Parts from this: http://www.novarossi.it/2012/images/files/esplosi/rex-car/LEGEND-28-8PS.pdf
Crank ($103): https://www.amainhobbies.com/novarossi-crankshaft-.28-nvr15802/p7840
OWB ($16): https://www.amainhobbies.com/novarossi-flange-complete-with-oneway-ball-bearing-528x-nvr22803/p6739
Backplate ($27): https://www.absolutehobbyz.com/Nova...o-Start--Pull-Start-Long-Stroke_p_510084.html
Starter ($16): https://www.absolutehobbyz.com/Novarossi-Pull-Start-System-21-28_p_501928.html
$162 total.
Would be better off sending it back and getting the right one if you can or it's going to cost you almost the cost of the entire engine would cost with the pullstart included:
$180 https://www.absolutehobbyz.com/Rex-...ngine-Turbo-Plug-Steel-Bearings_p_507703.html
