Hey guys ok I am really getting fed up! First let me give you the details
Savage xss (never seen nitro yet) Brand spankin new…. Ok so after I build everything I went ahead and did the throttle mod and the ofna tank mod.. working on led’s… I decided to learn about my spur gears.. anyways, after reading 1000’s of threads lol I realized mine was not properly adjusted. So I took everything apart to make sure everything is ok and it was not, my spur if I spin it, It wont spin straight its hard to tell but its as if something is crooked, but nothing is I checked everything took apart everything …its all fine! Now when I assemble everything and tighten the spring and spin it it’s a little crooked when it spins
So I told my self I cant ******* do anything else, its properly installed, I did the paper trick to get the right mesh and when I spin it it as if there is a part that get tighter on the on the spur!!!!
What to do, I'm absolutely lost (keep in mind I am good at these things usually, and very handy so its weird and really is making no sense!!! )
Help help help
Ohhh also when I was assembling my clutch for the second time I broke the little metal bushing at the end right before the last screw… after reading I notice some of you use fuel tubing, so I did the same is that ok?
Help help help
