I am building a new GT15c
rudeman
yes you should but just enough try not to over do it but you definitely need some to slide sleeve into crankcase
olds97_lss
Dekalb, IL 60115
I would definitely use something. Standard for any engine is to lube the bearings, con-rod bushings/contact points and cylinder wall while building so the first start isn't done with dry parts.
rudeman
a light coat of 2 cycle oil synthetic thats what i used and works great . i already built 2 gt15cc and not a porblem
rudeman
ok be carefull there's a little black knot on the piston right wear the ring go's you are go to line the ring right wear the piston ring close's. at first i broke the ring so i had to order a new ring i fond out the hard way lol. once you line it up sqeez the ring and slide in piston
Vmansavage
Cumberland MD
I agree with rudeman light coat of 2 stroke oil is what the motorcycle 2 strokes recommend when redoing a top end also I would also smear a thin coat on the cylinder wall and never had an issue
