HPI Vorza aluminum shock caps?
NitroNick
Does anyone know if these shock caps would fit the aluminum big bores for the Savage? Since that kit does not come with aluminum caps?
I cant seem to find the diameter of the caps anywhere, or the shock bodies...I think they are 12 mm? Again not sure about the caps...
Yeah I was looking at the manuals too. The bladder on the big bores is 16mm hence the inside diameter so they are the same there...hmm
The centers both use 3mm screws so that part works as well. Might be worth giving it a try, I'll contemplate it more when I buy some big bores
Hi
You might consider the Integy T6710 as a option.
