HPI Savage Replacement Diff Grease
Hunter90 HD
Hi All,
I have been searching around on eBay and online for a replacement grease (Z164 part number), and I am struggling to find any suppliers who has any in stock.
Can anybody recommend a suitable replacement?
I have been searching on some forums, and a few people are recommending ‘Moly Axle’ by Schumacher.
Can anyone vouch for this product?
I and rebuilding a few savages and need something that’s going to be as good or better as the HPI grease Z164.
Cheers!
Hunter90 HD
I use lucas red-n-tacky. Sticks to gears well and seems to do a good job. Some say it harms plastic, but I haven't seen that. Those that are concerned used silicone based grease instead.
This stuff is silicone safe and I've seen it suggested a few times for diff gears (ring/pinion):
https://www.fasteddybearings.com/dogbone-transmission-grease/
Hi,
Thank you! I will look at ordering some of this,
Thank you all for the replies! I will order some of this looks good stuff and will last longer than those small tubs :).
Thank you!
... how often do you change the grease? Do you find this stuff lasts long? How do you determine when it should be replaced?
SavageDarwin
I used CowRC Utter Butter on my last rebuild of the diffs. I'll have to look into some chain wax for outdrives and dog bones
Jam Racing 1
HPISF Supporter
all cow rc udder butter is is simply blue waterproof boat wheel bearing grease, and you can buy a large tube at most auto parts stores for a couple bux......
olds97_lss
Dekalb, IL 60115
Where can I get that at auto parts store or???
It's for bicycle chains, so a bicycle shop, or amazon:
https://www.amazon.com/White-Lightning-Clean-Ride-Squeeze/dp/B0016ZXE06
Shake it before applying it. I have mine in a different bottle with a longer nozzle to make it less messy to apply as the bottle it comes in likes to dump out a lot more than you need for RC stuff. I just have to make sure to clear the nozzle after using it each time or the stuff dries in the nozzle and clogs it.
Vmansavage
Cumberland MD
Thanks I will check my local bike shop if not I will get some from amazon
