HPI Savage Octane preview
WoodiE
Kind of good admin
HPISF Staff
Kentucky
Looking forward to this being released!
HPI Savage XL Octane Features:
  • Factory assembled, Ready to Run 1/8th scale Octane-powered Savage Monster Truck
  • 2.7hp GT15C 15cc 2-stroke engine with pullstart
  • 300cc fuel tank for over 20 minutes of runtime
  • Savage XL extended chassis with 3mm thick TVP plates
  • 3-speed transmission for aggressive action
  • 4-shoe Quadra clutch system with cooling fan
  • Triple-disc brake system for sure stops
  • XtraLarge Big Bore oil-filled shocks on each corner
  • Low fuel costs using pump gasoline and 2-stroke oil
  • All-metal shaft drivetrain for durability
  • Water-resistant receiver and battery box
  • Waterproof steering and throttle servos
  • Fully equipped with ball bearings for maximum efficiency
  • 2.4GHz radio system for hassle-free performance
  • Proven HPI Savage toughness
  • Extra-wide Terra Pin tires for maximum performance and grip
  • Brand new XL monster truck body
  • All-metal differential gears
  • Steel spur gear
  • Heavy Duty clutchbell
  • Heavy Duty dogbones
  • Heavy Duty outdrives
  • Heavy Duty axles
  • Machined brake hub
Interesting, but it looks like a stuffed pig in those TVPs. Also, what is with the tiny gasser? Only 15cc?
Took HPI long enough since I saw the first sneak preview of it it must be almost 2 years now.... hope they got all the bugs worked out waiting so long is tough to do.....
Maybe with Losi releasing their new gasser, HPI will pick it up and get the Savage Octane soon!
Unfortunately, last I've heard there is no release date yet on the Octane. :(
HPI has gone through a lot of changes in the last year.
I think they are in a re-grouping process trying to make sure they are in good shape before they release anything new other then minor changes to their existing products.
I have heard that the gassers are still floating around several manufacturers R&D rooms but nothing has been set for release.
that thing looks better than the Losi and 10X better than the Redcat. One can dream ...
Tower just put it back on their site showing availability in early May. I really like this truck but $869.00 is not for from a 1/5 scale which comes with a lot more power!
