Hpi savage mid-range needle
Savagekid
My mid-range needle blew out the side of my savage and I can't find one online I have been looking for one for the past month and nothing is there any way I could just block off the hole with something for a permanent or atleast a long lasting temporary fix. my engine is the k4.6 big block please help
lokky
The needle should control the flow so just blocking the hole may alter the tune. Try cleaning the hole and sealing with some rtv gasket sealant or similar, maybe need to part block with something solid so sealant doesnt go all way into needle housing. The orings go hard after a long while and thats why it probably came loose.
ELWOOD
HPISF Supporter
So.Cal.
@Savagekid
BLOCKING HOLE ISNT GOING TO WORK.
THE MID NEEDLE WORKS WITH THE LOW
NEEDLE SO IF ONE IS MISSING ITS A NO GO.
PROBABLY ONLY FIX IS A NEW CARB. HPI PART FOR YOUR CARB
IS A 15260 . REPLACEMENT PART PER HPI IS 15296
SEARCH FOUND ONE IN U.K. @ WHEELSPIN ,
https://wheelspinmodels.co.uk/i/14982/
58.89 Pound sterling equals
78.24 United States Dollar
Nov 21, 2:43 PM
olds97_lss
HPISF Supporter
Dekalb, IL 60115
The mid needle isn't a needle, it's the seat for the LSN. Without it, it's just going to dump fuel into the engine regardless how you set the LSN.
ELWOOD
HPISF Supporter
So.Cal.
@olds97_lss
I REALISE ITS A SEAT I JUST REFERED TO IT AS A "NEEDLE" BECAUSE THATS HOW HPI REFERS TO IT , DIDNT WANT TO CAUSE ANY CONFUSION....
#15282 - MID RANGE NEEDLE VALVE WITH O-RINGS
