How To Maximize your Steering
orcusomega
Royersford, PA
This article is meant to address some common issues with the steering on the various Savage platforms. This is not meant to be anything more than just a set of pointers for the newer members of the community. I am FAR from an expert, but being in the middle of the process of learning the ins and outs of the Savages, I wanted to share the stuff I have learned so far, and try to give something back!
So the steering, as a general consensus, has a few "opportunities for enhancement". In its stock form it works OK, with the later models having some nice improvements that are applicable to earlier models. So here is a list of things to look for and how to add these enhancements:
1) The stock steering on the older versions consists of a solid set of bellcranks and a servo-saver horn on the servo itself. This horn can absorb a lot of the turning power and minimize how far, and fast, your steering operates. One of the best ways to improve this is to remove this servo horn and replace it with an aluminum one, and move the servo-saver functionality to the steering bellcrank itself. The kit, HPI #87197 has all the replacement parts for the bellcrank, and the aluminum arms are also available as well (just be sure to get the right one for your brand of servo!)
2) The stock plastic bushings in the bell cranks are also prone to wear and additional drag. They can, and should, be replaced with ball bearings, you will need 4, and this will dramatically increase the fluidity of your steering as well. This has worked very well for me, particularly with larger tires.
3) Clearance your steering components! The Savage suspension and steering components are STURDY - and thick! This causes them to interfere with each other well before the servo runs out of throw. If you use a dremel, you can remove a lot of unnecessary material and really make your truck turn tight - especially if you have a longer wheelbase, this will help a lot! I was skeptical at first that this would weaken the parts to the point of failure, but I have not broken anything yet and I do beat on my truck LOL
4) Aftermarket steering components are available, but expensive. Look into the HPI RSC conversion if you want one that is pre-packaged. Note that the RSC kit only changes the outer components, and does not include anything in items 1 or 2 above.
I hope this helps someone to save the time and grief that I went through trying to find all this info all over the place 🙂
Bob
Hope this helps someone! I have a distinct advantage - I am writing up on what I have been actively learning 🙂 Being a noob, makes it easier to think of things other noobs can benefit from 🙂
What should be the next topic? How about everyone pitching in for a "Savage Bible" - no vendor pitches per se, but covering all the major bases?
Bob
I did this mod (Mod #3 on the list) to my stock XL and it does steer a little bit tighter. My turnbuckles are hitting (where they are connected to the wheel assembly) the bottom shock mounts so I don't think I can gain any more steering angle but I think the terra-pins have so much roll that is causes understeer. If I get different tires I think I'll see a little more benefit from this mod. It does turn a tighter circle when moving slowly though.
actually the part HPI #87197 is from factory in mine also mod # 2
so started mod # 3 and it's done
may be mod # 4 will be on mine soon
thanks again for posting Bob
Running the stock steering servo you need a 25t servo horn of a futaba horn. They are both the same.
Hitec is a 24t servo.
Once i shaved the knuckles, the difference was noticeable immediately! Great easy mod!
great write up bob thank you!!!! i have done all these mods except just buyin the rsc and i like them great and easy to do just be carefull with the dremmel it will bite back
eric...
Noticed that a lot of the links were dead in this write-up because of the SMF store closing. Went through and redirected to get working links again for those people that look here for info.
