Hong Nor exhaust pipe
Jabbo
Depends which savage, dual shocks, standard TVP-s?
Maybe link of the pipe as well, so I can see what bend the manifold has.
Polar_Bus
Heres the problem you need to be aware of when choosing a 1 pc. pipe for a Savage . Most of the pipe configurations available are for buggies. Buggy pipes are configured for a left side mount. Savages are a right side mount. This means the pressure nipple outlet is in the wrong spot. The other problem is the manifold spring retaining holes that secure the flange to the block will also be in the wrong location. I have had success making buggie pipes work with a savage but its a pia and requires mods. A 2 pc. Pipe design is no problem as you can rotate the exhaust in any direction to fit.
guinnessdublin
England
Okay thanks for info, will phone shop & see if they can advise!??
lokky
If you want the exhaust to point down then you need to drill new holes in the pipe for the springs. The manifold will fit in yours but you may need to make a hanger.
