k0m0d067
just out of curiosity, your THS pipes...do they have a number embossed on the gaskets? I'm trying to find out why in God's name my new pipe won't fit on my .28...the THS box says "THS8025 1/8 Savage .25-28 Engine Exhaust", but both of the gaskets that came with it have the number 21 embossed on the back of them...if you could check yours and see if they are the same I'd appreciate it...
I just spent the last 1/2 hour trying to coax the exhaust manifold onto the exhaust port of my .28, even going as far as to lube it up with dish soap to try and slip it in, with the final result being actually cutting one of the gaskets in half between the manifold and port...it's my guess that maybe the wrong hardware kit ended up in the package, or the wrong label was put on it...either way, I'm absolutely furious, because I wanted to start breaking the engine in this coming weekend and now that doesn't look very likely...
let me know asap, and if it's the wrong hardware kit, I'll probably have to contact THS directly, as I doubt the eBay seller will handle the situation...
the other possibility is that I'm some sort of retard that can't install a simple exhaust gasket...
