Hex nut
Jay F.
chalmette louisiana
Ok peeps, whats y'alls opinions on which hex nut set I should get. I want to use the stock tire rim setup for now. I'm looking at hpi's kit, but Integy has some nice ones. I may get the ones with a little offset in case I go with different rim/tires later on. I just like the look of the stockers but the little lovknuts a pain. The big hex nut makes it easier. What do yall think?
i have bought a few integy parts over the years and although they look sweet there alum doesent seem to hold up as well as others as it seems like its a softer alum but cant speak directly about the hexes as i haven't used them
as long as you keep in mind using an offset hex will put a bit more strain on the bearings and check them often they outta be fine....
I ended up ordering the hpi set. I have the silver hex nuts off an old buggy. I was trying to avoid the purple. Just a preference
