Rmadrid7
- Houston Tx
This is my first run after 10 tanks break in procedure. Please give me your opinion in anything you see wrong and I can improve ( tunning etc.)
I'm not 100% sure what causes that weird lean warble sound your having whenever you come off a high speed pass. Like at the 29-32 second spot.
For me, I'd want to richen the LSN and HSN as it sounds like it's starving a bit when the WOT pass uses up all the fuel in the crank case. It did it really bad near the end too.
Wide open throttle.
Those temps really aren't that bad....as long as they're on an average and not much higher...if you're getting good smoke and it's not crying for fuel... You should be goodohh... Later on that afternoon was much better. But i will rich it, because the temp. was around 240-250 fahrenheit. So probably i need to rich a little bit.
Thanks I appreciated your commentsThose temps really aren't that bad....as long as they're on an average and not much higher...if you're getting good smoke and it's not crying for fuel... You should be good
