gears i think
25 savage
i took out my front drive lines and was running it i was turning to go off a jump and it stopped going i thought it might be a spur gear but then i hooked up my front drive lines and it is in front wheel drive only what do you think is my problem thanks aaron
front wheel drive only right?
maybe the gears have stripped indeed but there is a small hex screw in the brake hub which might have fallen out.
it happened to me once and I couldn`t find the problem, I thought my gears were stripped also but when I checked the entire drivetrain from the engine down to the wheels I found a small hex screw missing:www.hpieurope.com/piw.php?lang=en&partNo=86094
if you replace it make sure the brake hub is clean and free of grease and put some loc-tite on it.
I just screwed in another one without cleaning the hub and it fell out again within 10 mins. ( I know I`m stupid, should have done it the first time! )
well i just looked at it and it is still there so i just might look at locking my rear end up some how
