engine ?
Thread starter #1
Likes
1
hey guys id like to know what is a good nitro engine for the savage 21 , i turned it into a shelf queen , i thought i would make it stronger by replacing all stock plastic parts with aluminum/titanium and never thought about the added extra weight . well when i finally fired it up i noticed right away how the stock engine struggled to get it jumping and moving all that weight so its time for a new engine anyway I'm looking for something with a little more power to get this up to stock speed, i really don't want so much power that it chews up the gears and spurs. any ideas ?
olds97_lss
Likes
336
Dekalb, IL 60115
Do you know if it has 4-spider diffs or 2 spider? The first savage 21 had 2 spider diffs and couldn't really support more power without at least upgrading that.
With that in mind, the HPI 25 would be a mild upgrade. Not sure what's available these days though.
The old 21 diff cases (the gear box the entire diff goes in) liked to flex, so a higher power engine would chew through ring/pinions quite often unless you upgraded the cases/gear boxes to alloy and shimmed them really well. That's what I ended up doing on my "21 chassis" savage back in the day.
The later Savage X gear boxes are tougher and don't flex as much. I ran an LRP28 in my X before upgrading the diffs to BP diffs, but it was still pretty hard on the machined diffs with smaller teeth. Once I upgraded to BP diffs, I didn't have many issues. Perhaps the BP diffs will fit in the 21 savage as well, at least the ring/pinion. rc4me.us has BP ring/pinions pretty cheap.
Here's a few:
https://www.rcplanet.com/engines/en...itro-star-f4-6-v2-engine-pullstart-hpi111595/
https://www.rcplanet.com/engines/en...-28-mach-2-pull-spin-big-red-monster-dyn0992/
https://www.rcplanet.com/engines/engines-car-truck/dynamite-28-rtr-engine-with-ps-dyne0571/
I can't recall which savage had that first engine, but it would be an upgrade in power over the 21 and 25.
I've seen videos of the second engine and I've had a few dynamites in the past. It's not a bad engine, but I don't care for the roto/pull start combo as it was kind of fragile.
The 3rd engine I know nothing about, but it has a regular pull start, which I'd be more inclined to trust. I can't imagine it's too bad. Dynamite engines usually run pretty good, hold a tune well and put out decent power.
X
Conspiracy of One
HPISF Staff
Likes
486
Minnesota
I'm curious, @bobbd, have you weighed your Savage? I'm fairly certain if somebody looks at your truck wrong it could bend. :eek:
