WSLR85
Hi
Replaced pull start because the pin broken earlier, I sprayed wd40 inside the engine (crank) to clean it and kept it for a day then put some oil to lubricate, then reassembled, I used ATF oil, there is some amount of oil in the engine not much,
What you say guys
-Using Wd40 was right?? For cleaning or as an antirust
-is it ok to for some oil to be inside or i need to remove it all??
-Using ATF or Motor oil for the engine? Bearings?
What you say guys
