Bicketybam
i am having an issue with a Dynamite Mach 2 .28 “Big Red” engine. After I run it for about 1/2 a tank or so it will suddenly stall. There will be no fuel in the fuel line. Even priming it at this point is almost impossible (by blocking the exhaust port and cranking it over). I have to pull the fuel line off the exhaust and blow into it to get fuel back into the carb. And sometimes I will see it run right back to the tank before I can reconnect the fuel line to the exhaust. I’ve checked the tank for leaks and there aren’t any. What else should I be looking at? BTW, this engine is not on my Savage. It’s on a Losi Muggy. Thanks!
