Dynamite .28
Discussion in 'HPI Savage' started by Zep71, Jan 12, 2018 at 1:29 PM.
  1. Zep71
    Zep71 Active Member
    103
    5
    Aug 12, 2017
    Ray City GA
    I bought a Dynamite .28 because i was told they are easy to tune. the one i have is nothing but trouble. i have it on my Savage 25. i have learned a lot about tuning and such from reading and what jam Racing has helped me with.looks like that Dynamite is going on a shelf and my HPI 3.5 is going to replace it.
  2. olds97_lss
    olds97_lss Well-Known Member
    1,092
    172
    Oct 2, 2015
    Dekalb, IL 60115
    Which 28 do you have? I think they have a few.
    What are the issues?
    Did you try sealing it up?
  3. Zep71
    Zep71 Active Member
    103
    5
    Aug 12, 2017
    Ray City GA
    yea i sealed it up the issue is i get it tuned good. and 5 minute later when i refuel it it won't start until take the HSN and LSP back to factory. i have done this more times then i care to count.
  4. olds97_lss
    1,092
    172
    Oct 2, 2015
    Dekalb, IL 60115
    Is it old? Has it sat for a long time without use(many months)?
    I have had engines that sat without use get the o-rings dried up. Then as it ran and warmed up, the needles would actually turn as it ran. Usually would lean them selves out on the HSN. Only had one that richened itself as it ran. After getting new o-rings, putting some green slime on them to help keep them fresh, the ability to tune came back and stayed where I put it.
    Sometimes you can coax a bit of life out of dried o-rings by taking the needle out, leave the o-ring on it, drop it in a small cup of fuel overnight to soak. This helps swell them back up.
    • Agree Agree x 1
  5. Zep71
    Zep71 Active Member
    103
    5
    Aug 12, 2017
    Ray City GA
  6. Zep71
    Zep71 Active Member
    103
    5
    Aug 12, 2017
    Ray City GA
    i bought it new back in October its has not sat around much.
  7. Jam Racing 1
    Jam Racing 1 NPTB Monitor, Master of the known universe.... HPISF Staff
    4,040
    551
    Jun 20, 2008
    Guess I have been either lucky or just good, I have had :ercm: from just about every manufacturer and have had good luck tuning them, I really like OS :ercm: but the price is high, but they do run a long time for the value factor, Currently my 2 newest :ercm: are a Force .32 in my XTM MMT and the Axial .32 I have in the Savage...
    • Like Like x 1
  8. Zep71
    Zep71 Active Member
    103
    5
    Aug 12, 2017
    Ray City GA
    I am not buying motors because they are cheap i have learned a lot over the last few months. i bought what i was told i needed before i knew better. if i knew then what i know now thanks to the info you pointed me to, i would have gone with a better motor
Verification:
Draft saved Draft deleted
Share This Page
