Cut off problem
Alireza
Hello
I have a Savage xl flux and I set the LiPo cut off setting to 3.4V/cell and even test others but the ESC persistantly cut off on 3.7v/cell.
I hope someone can help me on this issue.
Thanks
Not sure how sensitive that ESC is, but it's possible that it's seeing a momentary drop in voltage due to heavy load.
I have seen this in all my cars. I have castle creations esc and some hobbywing ones. I think X is correct. From my experience when the LVC shuts everything down, it re-arms after a min and gives minimal power but when I give full throttle the LVC cuts it off again. When I test the batteries the voltage is always higher than the pre-programmed cutoff. I'm ok with it happening, Lipos get a bit pricey and if it saves me $50 I'm happy.
