Converting savage xl to 1/5, w/mamba xlx
geezer
Already started build i will post pictures soon
Cut out one of the tvp's working on the next one. Will be using the savage xl octane center differential shell. The nitro savage xl 3 speed gears are transferable except the two shafts, one is the drive shaft and the idler shaft.
Here is motor mount
Mamba xlx motor on motor mount, i will post more pictures with the TVP's attached.
20170505_203722.jpg here is the mamba xlx esc & steering servo installed onto custom plate
20170505_204518.jpg here it is both tvp are complete & parts assembled and installed. not finish have to tuck wires, make a radio box & two battery trays
Added battery trays, and radio box, still some small details to finish it. Major one is acquiring two batteries, would like to use two 4s, 50c, 5000mah.20170507_170003.jpg
Just posted a running video on you tube do a search for mamba xlx Savage, mind you it is running 4s waiting to acquire another battery. Then I will post another video running on 8s
