clutches and gears
Andy Fraser
Saudi Arabia
Hi Guy's - looking for a little advise - since it is the weekend in this part of the world I had chance to do some strip down work on my recently acquired X4.6 - unfortuneately the previous owner gave it to me because it didn't run well - but after today I can see it's mush worse than that and will need much more to get it back to former glory - I have tried to attach some pic's but failed so I have tried to explain each component. I was wondering if this type and number of failures are normal - or is there something more serios I sould be looking at?
Clutch shoes - look to be worn on outer edges and the mounting holes have elongated - clutch bell - the gear is worn as though it was poorly meshed - slipper clutch - cracked and contaminated. They all need replacing but I was looking for advise on going stock or modified - I know the spur was replaced with a steel replacement - current gearing is 15/49 - is this a good ratio for general use - and as I live in the worlds biggest sand box will it work on the dunes??
Any help would be appreciated
15/49 is definatley an all around setup. these replacement parts it needs are all rather cheap though. spur gear is like 4$ for plastic, Clutch is cheap as well...i would get an upgrade clutch, a lot of people like aluminum but i like my mugen seiki carbon shoes. they were cheap and they grab like woa
Andy, from the sounds of it your not in real bad shape. lets work on getting those pics in this thread first caz we will diagnose the problems better & find the least-costly & most effective solutions.
hit this thread https://www.hpisavageforum.com/forums/showthread.php?t=3167
I managed to get some pictures uploaded - thanks for the advise
Slipper was to loose, need a hardend clutchbell to run a steel spur, and the plastic shoes are junk. So get a hardened clutchbell, new slipper pads, nova clutch shoes, mugen 1.0 springs. That should hook ya up nicely.
andy your not in bad shape there bud. only thing i see is your bud used a hardened steel clutch bell with that steel spur gear.
you need to use a hardened racing clutch bell with that metal spur gear caz (as shown in your pic) the steel on others just isnt hard enough.
1. Here is what a hardened racing looks like http://storefront.smfstore.com/index.php?main_page=product_info&cPath=31_68&products_id=611
2. might as well grab yourself a couple metal shielded clutch bell bearings
http://storefront.smfstore.com/index.php?main_page=product_info&cPath=53_54&products_id=1705
3. your clutch shoes look fine to me.
4. your slipper pad on the spur gear looks a bit worn but ok. might as well replace the pad while you have the spur gear off the truck http://storefront.smfstore.com/index.php?main_page=product_info&cPath=31_185&products_id=398
5. then get yourself a good 7mm socket & crank that slipper nut down good & tight all the way, then back of 1/8 turn as per your owners manual.
6. makes sure you understand how to properly mesh your spur gear to clutch bell & your off & runnin. rockout
