Cleaning
Mikey D
Hey guys, i wanna hear yalls methods of cleaning your trucks spot less to see if i can start cleanin mine better. I usually use glass cleaner an air. How bout yall?
Oh, an i run nitro. Also wanna see if any of you are running end bleed pipes an what yall use to keep it off the front suspension cause it covers mine even with a 45 degree pipe extention.
i like to use the spray on foam engine degreeser for real cars..i use the cheap walmart brand 2 bucks a can ... works great .. spray it let it foam up till it starts dripping off the grimm. then spray off with water hose making sure to avoid motor and electronics .. then air hose it off... looks brand new when done...
Ive used it on 1:1 vehicles bein I'm a mechanic, so ill have to give it a try.
simple green and wd40, wash it down air it off. Whatever you do, beasure to air your rc off.
i use a thing called muc off as it is not as strong a cleaning stuff u use on road cars but still dose the job then air it off with air line then i cover her in GT85 witch again smells grate and is a better finish and no need to wash the muc off with water it takes me about 20 mins and it look like a new truck
remove motor and electrics. throw it in the dishwasher with your choice of dishwasher soap and push go. just make sure to run the dishwasher a second time empty to clear the residue from it before the wife finds out. it does work awesome.
I use wab cab cleaner. You can get it at any big truck/parts shop, like Peterbilt, Cat etc. Just spray it down and blow it off.
