Cleaning my savy
-SaVaGe X-
Ontario Canada
hey guys what is the best product to use to clean my truck? is there a special nitro truck cleaner or do i just use water? plz let me no what u have used and if it worked good or not.
thnx
Heres what I do:
Remove the tires and clean them in my deep sink with soap and water.
Remove the radio box and engine
Then hose the entire truck very well
Then set your truck on your deck or whatever and let it air dry
If you have an air compressor use that as well
I do this every 2 months or so, no need to clean it that much unless it's caked with mud or something.
I also have started using 1/2 and 1/2 water and simple green. Works great.
2 parts denatured alcohol
1 part simple green
1 cap full wd40
always shake the bottle prior to use
if you have a air compressor then use it if not just let it air dry as stated above
