Cen box mod.
SL63
Midwest
I have already modded the bottom half , turned out great , only problem is the top , i cut in the hpi battery level led no problem , plan on adding the ernst charge jack as well , i' m running a 370 oz jr for the steering & i have a 142 oz for the throttle & brake , i plan on putting a ballistic 2700 mah so i need to level the top of the box so everthing will fit , this should not be a problem , i'll post some pic's when finished , i did all the measurements & all should go as planned , i'm running the flm ext lcg's & purchased the bigbores as well.* Well decided to go anther route & run a 192 oz servo up front & install a 1700mah so i don;t have to mod the box anymore , when finished i'll post a pic.
SL.
