Can I use this car grease / lube on my savage XL ?
Atarioldskool
Leicester UK
Hey
I purchased this grease / lube but just wondering can I use it in my rc, particular in the diff - pinions, gears etc ?
I would have thought if it’s good enough for motor vehicles it should be good enough for rc ?image.jpg
Sparky
Yep pack the inside of the diffs, will work good,
I stopped putting silicone did fluid in my rc's a while back as it doesn't last as long
as a well packed with grease diff,
The silicone fluid allows a lot of diff slip after a couple runs.
Jam Racing 1
HPISF Staff
yes use a heavier grease to "tune" the differential, I prefer to use a heavy red chassis automotive grease in my diffs......
Jam Racing 1
HPISF Staff
Would that kind of grease be close to 50wt silicone or is just a case of trying different grease ?
You can find it at most auto parts stores, it sticks well to the parts, not sure if it is comparable to 50 weight silicone oil. it is pretty heavy I guess considering I packed the diff cavity full then put on the ring gear....
Jam Racing 1
HPISF Staff
https://www.amazon.com/Lucas-Oil-10005-Tacky-Grease/dp/B000ARPVO8/ref=asc_df_B000ARPVO8/?tag=hyprod-20&linkCode=df0&hvadid=312151579877&hvpos=1o2&hvnetw=g&hvrand=17893837698967310847&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9032320&hvtargid=pla-433746407250&psc=1
I know a guy who is using this, I had a couple tubes half full on my shelf and that is why I used the stuff I had, it was there and fit the bill. I am mostly a basher anyway and all I know is it works for what I want to do......
Savage 6768
New Zealand
Sweet I might give the grease a try as just used the last of my silicone diff oil, I wonder if the grease is more suited to nitro or the brushless Savages ?
olds97_lss
Dekalb, IL 60115
I use 50K oil in both my nitro and brushless savage in the diff cup and regular axle grease on the ring/pinion. I never tried the red marine grease, so not sure how it reacts, but 50K in the cup gives you decent power to the wheel on the ground if the other wheel is in the air. I never noticed the action changing after a couple runs with oil. I've noticed that with grease as the grease tends to get a path cut through it, then doesn't do much. I only used typical axle grease then though.
The red marine grease is supposed to be pretty sticky. I may order some of that to use instead of the axle grease on the ring/pinions.
