Can anybody help me identify this problem on my savage ?
Discussion in 'HPI Savage' started by GLISEON, Jul 21, 2017.
Tags:
  1. GLISEON
    GLISEON Active Member
    Jun 30, 2017
    106
    4
    Hello, I've been having some issues on making my savage x run right. Before it was like this it was running well and then I stripped the spur gear which I think from bad meshing. Now that I replaced both spur gear and clutch bell to heavy duty variants, I've been having this underwhelming problem. Whenever throttle is applied it bogs very bad, I brought it to factory settings and I know it's supposed to be running at a fair speed. But it just feels, and seems like it's drowning. Could this have been caused by a incorrect clutch bell placement or anything along those lines? Please any help would be greatly appreciated. I left a video under so you guys can have an idea on what I am experiencing.
    (P.s leaning any of the needles does not help)
    Thank you.
  2. Jam Racing 1
    Jam Racing 1 NPTB Monitor, Master of the known universe....
    HPISF Staff
    Jun 20, 2008
    4,352
    621
    sadly that vid is so short and with you pulling the throttle like that it is going to be very hard to help diagnose anything it may be doing.....
  3. GLISEON
    Jun 30, 2017
    106
    4
    Sorry about that ); but what I noticed is that the clutch shoes are turning freely in the clutch bell and not really engaging inside. Is that supposed to be happening?
  4. coreyh29645
    coreyh29645 Member
    Jun 17, 2017
    46
    13
    stafford springs ct
    are the shoe on right?
  5. GLISEON
    Jun 30, 2017
    106
    4
    I never tinkered around with the shoes, but I changed out the clutch bell. Maybe it's not pressed enough on the shoes as in the video you can see the shoes from the back of the clutch bell
  6. J.LO's SAVAGE X
    J.LO's SAVAGE X Well-Known Member
    Dec 3, 2016
    530
    29
    eudora kansas
    also look for air leaks! when you took stuff apart to fix, may have developed an air leak, check gasket around exhaust header that mounts to engine block, could be bad , also check gasket between header and muffler , that zip tied gasket may nee re zip tied and good and snug , also might check fuel lines, if old replace, and maybe check tightness on cooling head bolts.
    • Like Like x 1
  7. GLISEON
    Jun 30, 2017
    106
    4
    Ay thank you ! You know what the gasket that seals the muffler and header is quite loose. Have to tighten and check all those other spots too!
  8. J.LO's SAVAGE X
    Dec 3, 2016
    530
    29
    eudora kansas
    easy cheap fixes, also make sure your brakes aren't too tight, and clutch bell is free spinning.
    • Like Like x 1
    • Agree Agree x 1
  9. GLISEON
    Jun 30, 2017
    106
    4
    Ok man I will! Brakes are bad right now but installed a new servĂ­ but the stock servo horn is to small to fit
  10. Grumpy1822
    Grumpy1822 Savage Owner
    Mar 13, 2008
    749
    11
    Kenner, Louisiana
    If you hsd an air leak it would run kean and high idle. Leaning the lsn should raise the idle. Idk how it wouldnt.
    You shouldnt have had to mess with the needles just swapping a spur gear.
    • Like Like x 1
  11. GLISEON
    Jun 30, 2017
    106
    4
    idk man honestly I don't know what the truck has at the moment but I'm going to try everything to make it run how it's supposed to
  12. GLISEON
    Jun 30, 2017
    106
    4
    Fuel on outside of both gaskets. Is this caused by an air leak ?
  13. Grumpy1822
    Mar 13, 2008
    749
    11
    Kenner, Louisiana
    That little bit is normal. Esp if youre running rich and using fuel with a lot of oil
  14. GLISEON
    Jun 30, 2017
    106
    4
    Oh ok makes sense. Cause it has been at factory settings. What do you think it could be ?
  15. Grumpy1822
    Mar 13, 2008
    749
    11
    Kenner, Louisiana
    Rich lsn. Really need a better video one whete you put it ob the ground and try to go
    • Like Like x 1
  16. GLISEON
    Jun 30, 2017
    106
    4
    Here's a vid of it running on the ground. This was at base settings.
  17. NightFlier X4.6
    NightFlier X4.6 Well-Known Member
    Mar 21, 2015
    1,074
    163
    Ohio
    I think it sounds really rich even at stock and you've tried leaning it out a 1/8 turn at a time to see if it gets better?
    • Like Like x 1
  18. GLISEON
    Jun 30, 2017
    106
    4
    Yes sir , same thing after that ):.
  19. NightFlier X4.6
    Mar 21, 2015
    1,074
    163
    Ohio
    I cant help but think there's a problem with either the fuel tank or carb.
    • Like Like x 1
  20. GLISEON
    Jun 30, 2017
    106
    4
    Doing an old trick by putting a ballon on the carb and seeing if it deflates to confirm I have an air leak. Any other methods to checking for air leaks ?
  21. Sumo Savage
    Sumo Savage Active Member
    Aug 19, 2016
    63
    1
    Chandler, Arizona
    Take off engine and Blow air through fuel inlet and plug the air filter hole and exhaust manifold hole and brush on soapy water and look for bubbles
  22. Grumpy1822
    Mar 13, 2008
    749
    11
    Kenner, Louisiana
    Its not an air leak. An air leak will do the opposite of this. Hes running rich, both needles. I'm also thinking the brake is dragging. You mentioned messing with the brakes and servo horn. Do the wheels spin freely?
    • Like Like x 1
  23. GLISEON
    Jun 30, 2017
    106
    4
    Even if I am running rich it's at factory settings and should run fairly at that. But that's a good point with the brakes because they are honestly so unresponsive. When i push it it feels a little hard
  24. Grumpy1822
    Mar 13, 2008
    749
    11
    Kenner, Louisiana
    Truck should roll freely with a nudge fron your foot. If its not rolling freely, thats your problem. Either linkage setting, horn position, trim setting or brakes are assembled wrong
  25. GLISEON
    Jun 30, 2017
    106
    4
    Nevermind truck rolled freely. I'll be posting a decently long vid on Wednesday of the truck on idle and rolling.
  26. MySavageWillBeatYours
    Jun 27, 2017
    23
    6
    Raleigh NC
    Factory settings are for break-in and are very rich. You need to lean it out and make a WOT run after each adjustment to clear out the crankcase. Make 1/8 turn adjustments until you see the performance pick up then make 1 hour adjustments to fine tune it. Once the HSN is set then lean the LSN 1 hour at a time until you have a nice crisp takeoff and smooth idle. You can tell its very rich now by the oil trail its leaving. You should have a very fine mist of oil droplets coming out the exhaust at idle when its set right.
    • Like Like x 1
  27. GLISEON
    Jun 30, 2017
    106
    4
    Will be posting video up later showing, startup, idleing, and running.
  28. olds97_lss
    olds97_lss Well-Known Member
    Oct 2, 2015
    1,520
    254
    Dekalb, IL 60115
    I'll second the fact that "factory" settings are typically overly rich for break-in purposes. It's a base line, not a "good running" setting. It seems to idle for you, so focus on the HSN until you can get a clean WOT run, then dial back the LSN a bit so it doesn't load up really bad when sitting/idling for 15 seconds or so.
    • Like Like x 1
  29. GLISEON
    Jun 30, 2017
    106
    4
    Hey man that's exactly what I did today and it was running well! Thank you everybody for the help
  30. GLISEON
    Jun 30, 2017
    106
    4
    Little bashing today !
    • Winner Winner x 1
Share This Page
